Beiträge von AstraK2015
    Kühlmitteltemp. (86 °C)
    ■MAP (100 kPa)
    Einlass-Lufttemperatur [40 °C)
    Kraftstoffdruck 1310 kPa
    Abgasrückführsystem [0%]
    Markibnis angeforderte zu aktue
    Baro. Druck [102 kPa)
    Angeforderter Ansaugluftstrom A
    Relativer Ansaugluftstrom A Position
    Angeforderter Ansaugluftstrom B
    Palativer Ansaugluftatiom & Pos
    Reset trip []
    Berechneter momentaner Kraftstoffverbrauch (po L/100km)
    Additional heater relay 2:3 []
    Air Con High Side Pressure (682.44
    Air flow [
    Air pressure [kPa]
    Air to Fuel Ratio []
    DPF Inlet temp [634]
    Balance Rate (Cyl 1) [0]
    Balance Rate (Cyl 2) [0]
    Balance Rate (Cyl 3) [0]
    Balance Rate (Cyl 4) [0]
    Balance Rate (Oyl5) [1
    Balance Rate (Cyl 6) []
    Balance Rate (Cyl 7) []
    Balance Rate (Cyl 8) []
    Barometer V6 [kPa]
    Barometer VB [kPa]
    DPF flow [0.09 kPa]
    Omd. boost 199.43 kPal
    Idle RPM [776 rpm]
    Cmd. turbine blade [%]
    Current Gang (AT) []
    Desired Idle Speed [rpm]
    Dist, since regen [km]
    Dist, since DPF regen. [150 km]
    Diff. press. [0 kPa
    Diff.pres.sen [0.58 V]
    HO2S 1 [828.78]
    HO2S 1 Conc. [14.15%
    ■HO2S 2 Conc. [0%]
    DPF dif.stat [0]
    DPF soot [32.16%
    DPF soot var.3 (0.32%]
    DPF soot v.2%
    EGR bypass []
    EGR com. [6.27%월
    EGR% [19.22%
    EGR V [3.8 V]
    Elapsed Time Since Engine Start 19
    Engine Oil Pressure 10 kPal
    Engine Oil Temp 187 C
    Engine Torque [Nm]
    EVAP[N]
    EGT #1 [145.5°C]
    EGT #2 [172 C
    EGT #3 10 °C)
    Fuel pressure reg. [치
    Fuel rail [31.58 kPa
    Fuel Tank Pressure [kPa]
    Fuel temp. [C]
    H20S Sensor [mv]
    Heater relay 1 []
    IAC Position []
    Ignition 1 Voltage [V]
    Inj #1 bal. [%]
    Inj #2 bal. [%]
    Inj. #3 bal. [%]
    Inj. #4 bal. [%]
    Injector PWM Bank 1 [ms]
    Injector PWM Bank 2 [ms]
    Intake Air Temp 2 (IAT2) [
    Knock Retard[1
    Knock Retard [
    Knock Retard (ALT) []
    Knock Sensor Active Counter []
    Last Shift Time | sec.]
    Misfire Cyl 1 Current []
    Misfire Cyl 1 History []
    Misfire Cyl 2 Current []
    Misfire Cyl 2 History []
    Misfire Cyl 3 Current []
    Misfire Cyl 3 History []
    Misfire Cyl 4 Current []
    Misfire Cyl 4 History []
    Misfire Cyl 5 Current []
    Misfire Cyl 5 History []
    Misfire Cyl 6 Current []
    Misfire Cyl 6 History []
    Misfire Cyl 7 Current []
    Misfire Cyl 7 History []
    Misfire Cyl 8 Current []
    Misfire Cyl 8 History []
    Odo miles
    Outside Air Temp [C]
    PC Solenoid Actual Cument [mA]
    PC Solenoid Reference Current [mA]
    Rem.eng.ofl (var.2) [%]
    Remaining Oil Life [%]
    IPW #1 [ms]
    IPW #2 [ms]
    IPW #3 [ms]
    IPW #4 [ms]
    IPW #5 [ms]
    IPW #6 [ms]
    IPW #7 [ms]
    IPW #8 [ms]
    Gang (AT) ratio []
    Ich war bei meinem Händler und mein Ansprechpartner hat in den Motorraum gehorcht und meinte direkt, dass das keine Kette ist und es alles gut klingt. Er zeigte mir danach eine Aufnahme mit dem Geräusch eine gelängten Kette. Das Geräusch war schon deutlich brutaler. Anscheinend habe ich auf das falsche Geräusch geachtet. Es stört mich zwar weiterhin, aber dann muss ich jetzt lernen darüber hinwegzuhören :D Den erhöhten Spritverbrauch (heute gemessen mit einem Liter mehr), soll ich laut ihm längere Zeit dokumentieren, um das ggf. mit der Garantie geltend zu machen. Ich mache das Thema erstmal dicht, da das Problem ja "geklärt" ist. Danke für eure Beiträge.
    Heute morgen wollte ich eine Aufnahme aus dem Motorraum machen. Beim Abhören der Aufnahme habe ich dann feststellen dürfen, dass sich mein Handy beim Motorstart mit dem Radio verbunden hat und ich daher keine brauchbare Aufnahme habe... Bevor ich einen neuen Versuch starte, gehe ich heute zu meinem Händler und führe das Problem vor...
