. Hi from Greece.I own an astra k 999cc. Turbo. It presents me with the following problem.... when the engine is cold it works normally. However, when it warms up it presents me with the code p0011. I have changed the variator gear and the valve but the same problem continues. Please if anyone knows, please help me. Thank you
P0011 problem. Please help
Hello,
have you already read the following article: Fehlercode P0014 durch zu wenig Öl???? It also deals with your/the 1.0 engine and the error code you mentioned...
Regards, Uwe
ok. Thank you very much friend.
I'll check it on Monday.
Check Oil , Nockenwelle out of order, wrong Oil ? Dust ...etc can be...much Luck !
Nockenwelle
camshaft ...
